Penta Discuss Volvo Penta Marine Machines Within.
Tamd 74 edc only starts in limp mode
Old Sep 4, 2025 | 08:35 PM
rscott1956's Avatar
Default Tamd 74 edc only starts in limp mode
Hi everyone I’m new here. I’ve got a TAMD 74 EDC engine on my commercial fishing boat and after using it for the last 4 months it all of a sudden started only starting in limp mode. When I press the active station (key button) on the control pad the red light that normally is supposed to stay solid red blinks a bunch then goes out. If you start it, it immediately goes to 1000 rpm and the throttle is disabled and will not work. I have tried a new control pad, key switch, examined the plugs on wiring harness that I could see and cleaned and reconnected, checked grounds and positives on starter, disconnecting battery and reconnecting and nothing has worked. Has anyone had something similar happen? I also attempted to recalibrate the controls and when I tried the red and yellow light on the control bad just blinked simultaneously and would accept my inputs. Is there anyone on here familiar with these engine and know what it could be that’s causing this? Any ideas would be great
-Robert
Old Oct 10, 2025 | 05:07 AM
sestgus5's Avatar
Hey, If you turn on ignition only and press D or Display on the panel, what are the error code ..?
Svein
Aug 2, 2023 01:09 PM
Marhan
2001-2013 model year V70
Mar 17, 2022 10:56 AM
colin davies
Oct 16, 2020 04:50 PM
elpopio
Sep 21, 2019 08:20 PM
brianeno
May 31, 2012 11:16 AM
