TIming Belt for AQ171C
I have an AQ171C that I need to find a timing belt for. Can I use the timing belt from a Volvo 1992-1995 740 or 940 for this? If not does someone know were I can get one without costing an arm and a leg?
Auto parts stores can find a belt for you. Their catalogs have off-road and marine listings.
A Dayco or Gates application should be no problem. An old number can help too. Check marine forums and maybe Turbo Bricks has some info. Ed |
I found a belt on line that matches teeth, pitch and length. The only issue is the width. The width is about 2/16" wider than my current belt that is 15/16" wide. The belt is 1.1" and the gear is 1.5" wide. Does this sound like it will fit? Here is the link:
Buy Dayco Timing Belt 95319 at Advance Auto Parts |
Seems as if it's close enough. The limiting factor is the width of the crank gear.
Ed |
It's just a 16v redblock, any 16v belt will work.
