Sights N Sounds Post all of your video and sound clips here.
Xc60 intermittent dipped beam light failure
Old 10-08-2019, 03:24 AM
Chrismix103's Avatar
Default Xc60 intermittent dipped beam light failure
Morning all. I've seen similar posts but nothing that gave an obvious answer to my issue. From what I could see anyway!
My xc60 (2010) stated to come up with a headlamp fault, dipped beam fault.
Nearside light is out. I took it out to check the bulb. It's a ORSAM 66146 HID bulb.
If I turn the lights off and then back on shortly after, it comes back on for a while then goes off again.
Does this sound like it's actually a bulb fault or something else like the connectivity for the HID?
Any assistance would be appreciated before forking out for a bulb that might not need replacing.
Old 10-08-2019, 03:25 AM
Old 04-21-2022, 01:32 PM
CHavenga's Avatar
Default Bulb Failure - Dipped Beam
Hi.
I know your post was quite a few years ago but I would like to know what you managed to find out about this issue and if you could resolve it.
I have a 2010 XC60 with the exact problem.
Both lights (on dim and bright settings) are now flashing/flickering.
It was first just the left and now the right side as well.
Volvo service centre reckoned to replace both bulbs at R6000 which I need to know if this can be done by an auto electrician perhaps for cheaper?
And IF it is in fact the bulbs that need replacing.
Your feedback would be greatly appreciated.
Macy517
04-27-2019 05:26 PM
cunning
11-09-2018 07:54 AM
dave317
01-23-2018 06:08 AM
Hockeydad2366
09-02-2017 07:14 AM
Smoreeng
03-16-2016 11:58 PM
Quick Reply: Xc60 intermittent dipped beam light failure
