Encyclopedia Thread
6 Attachment(s)
I have created this thread to have a place to stash and test pics for uploading. The picture files below were too large to use as attachments so for now, I'm linking them to Photobucket.
The following will be reposted in the appropriate thread once I'm sure the format works. There will no doubt be more posts in this thread as issues with the car arise. Here is the left (driver's side) headlight wiper/washer on my '00 V70 XC. The P.O. snapped off part of the bracket that holds the wiper when they tried to replace it and were apparently stumped on how to fix it. Enter Dig. Note that I have already wiggled the fluid hose and removed it from the nipple which is just below the headlight to the far right in the pic. For photo reference purposes, I placed it back into position without actually fitting it back over the nipple. Attachment 18706 The cap that covers the nut on the wiper stem flips up for easy access. Attachment 18707 It's probably metric but I used a 5/16th socket and ratchet with no problem when I removed the nut. Attachment 18708 The arm is mounted on a shaft with a tapered spline so you'll need a pair of pliers to grip and wiggle it to pull it off. Attachment 18709 Voila! Ready to reverse the procedure to install the replacement. It's off to the "Pick 'n' Pull to see if I can find one. Attachment 18710 Note the tapered spline. Attachment 18711[IMG]https://volvoforums.com/forum/Attachment 18706 |
Handy links that I want to keep around.
TECH TIP #10072 - Reset Service Light in 1998 & Later Volvo Models TECH TIP #10061 - Fuel Pump Whine - 1998-2000 V70XC Models |
