Fog light help
I just purchased a 2005 V70. There is a button on the dash to apparently turn on rear fog light but it does not have front fog lights. I wanted to throw some after-market fogs on the front of the car and wire them to the button for the rear. Is this possible to do?
Thanks |
Originally Posted by HARRINGT0N
(Post 447595)
Thanks |
Originally Posted by Smith Volvo
(Post 447598)
I would not do this because the fog lamps are controlled by your CEM and REM and I believe would cause issues. I would recommend the factory kit #30744346 and wire harness #8622840. Would still need a software download also.
If you want to do it the right way, yes. And yes, the dealer does the software.
You can try your method but the CEM/REM might detect a higher than usual draw and shut the circuit down. You would have better luck adding a circuit direct from battery voltage and using a generic switch installed somewhere. |
Originally Posted by ES6T
(Post 447623)
