Help me
i have a XC90 2009 with 3.2ltr. And I have a squealing noise coming from my engine.. When I pull the dipstick out it goes away and if I put my foot down.. It is getting louder need to fix.. Help Troy
pulling the dipstick will vent crankcase pressure. the noise is likely an air leak somewhere that needs to be traced. I'd also test for excessive crankcase pressure (you can try removing the oil fill cap, then put a latex (ie surgeons) glove over the oil filler - if it inflates and stays inflated, you have positive crankcase pressure, which could be caused by a clogged PCV system. (and you'd want to fix that before it starts turning into leaky oil seals)
