No FM stations with my 1997 S90
My S90 will not pick up any FM stations. The antenna is plugged into the back of the head unit, and the antenna wire if plugged into the antenna in the trunk. Any suggestions?
Originally Posted by rspi
(Post 210481)
Well, I swapped the radio into my other car with the same results. Somehow the FM side is gone.
what unit is it?
Not sure, but my 850 manual says that you could set different frequencies of FM base on what country you're in. Could it be possible, I'm guessing it forgot its settings some how?
Maybe. I'll check into that and see what happens.
