2005 S40 T5 parts
Have remnants of a S40 T5 which was rolled. Already sold motor and trans but have a bunch of other goodies left such as electronic modules, brakes, intercooler, radiatior , window regulators etc. Middle TN southern KY area.
If you need anything let me know, as soon I will be crushing what is left. |
I know this way late but do you have an ecu / fuse panel or a heater coil left from that 06 volvo?
Yes, have the ECU for sure a I removed it and have it set aside. The heater coil? You taking about the heater core? It is still in the car, but it looks like quite a job to remove it..
But yes, I have have both parts. |
Okay does it matter that my volvo is an 06?
I have no idea on compatibility between 05 and 06, that is something you will need to research, as I wont be qualified to answer. And at this point we are only talking about the ECU as I crushed the car last weekend. The car was a 05 S40 T5 turbo. If yours is an 06 S40 T5 Turbo, then what parts I have left may just fit your car. I have the PCM and ECU and intercooler/radiator starter etc. Just misc bits and pieces. But as I said, I sent the rest to the recycling center to get my garage back.
S40dude, the ECUs are likely to be the same if both cars are T5s - what you can do is search for the volvo part number for your 06 car via a dealer website then compare to the PN for the 05s. The ECU should have the part number right on its label if its accessible... if you can view yours, you can also do a google search to find compatibility years.
