1984 244; overdrive will not engage
I have a 1984 volvo 244 sedan. The "OD Off" light is illuminated on the dash and the car will not shift into overdrive. What is causing this problem? Switch? Transmissions problem? I am considering installing the solenoid bypass kit, but am not sure it will cure the problem. Thoughts or suggestions? Thanks.
RE: 1984 244; overdrive will not engage
Can you turn the light on and off with the switch?
If not then I would look at the relay first. |
I was hoping I would hear from you, TECH.
No, the light does not go on and off...it stays on. Where is the overdrive relay located? |
It is a pain to get to you need to remove the glovebox.
Then it will be behind the center vents. It is a white relay that is pretty long. Sometimes you might be able to resolder it and it might work. |
| All times are GMT -5. The time now is 03:21 AM. |
