1989 Volvo Wagon 750 With Turbo .Problem Cuts Out When Turbo Engages
I Really Need Help I Have A .1989 Volvo Wagon 750 With Turbo
It Start And Run Good No Problem There But When I Step On The Gas Pedal And The Turbo Engages The Engine Will Cut Out And Die And It Can Drive Around A Little Bit But When That Turbo Engage It Will Shut It Down :confused: I'm Trying To Fix It For My Brother He Got A Baby On The Way And The Car Is In Really Good Shape No Dents Everything But That Issue With That Turbo Thank For Any Help |
Originally Posted by lukesvolvo
(Post 328876)
It Start And Run Good No Problem There But When I Step On The Gas Pedal And The Turbo Engages The Engine Will Cut Out And Die And It Can Drive Around A Little Bit But When That Turbo Engage It Will Shut It Down :confused: I'm Trying To Fix It For My Brother He Got A Baby On The Way And The Car Is In Really Good Shape No Dents Everything But That Issue With That Turbo Thank For Any Help did u ever fix this problem? |
(Post 328876)
Any air leak between the air mass meter and the throttle plate can cause a power loss, such as a hole in one of the inter-cooler hoses, on the exhaust side from the turbo to the inter-cooler, Air mass meter to turbo, and the 2 short ones at the top on the drivers side - all get holes in them - OR Look in the air filter box - there's a foam pad that comes off and blocks the flow of air into the air mass meter (i imagine that's been gone a while though) - OR The fuel pump is failing, under high boost/high fuel demand the fuel pump can't deliver enough fuel and the system goes very lean - OR Many other possibilities - |
Lukesvolvo hasn't been on this forum since 2012
Originally Posted by pierce
(Post 490731)
| All times are GMT -5. The time now is 12:27 AM. |
