1991 240 Wiring Identification
Hey Guys,
I have a short somewhere that's frying a wire under my dash, I cannot figure out where it is going to or from, attached is a picture of a 20 wire connector behind the brake pedal. It is the light brown wire, or #6 on the connection. The wire joins a larger bundle and goes into the dash near the steering column. Any help would be appreciated, if you know where the wire goes or have a wiring diagram that could show me it would be great. I couldn't find any diagrams that helped with a google search.
Thanks
Dylan
Thanks
Dylan
according to the grenbook, that connector is 24 pin? (assuming I'm looking at the same connector), and pin 6 is white and goes to the license plate light.
to verify we're looking at the right connector, other pins are shown as follows...
1 - fuel level sensor (grey)
2 - direction indicator left (blue-green)
3 - direction indicator right (blue)
4 - rear fog light left (violet)
5 - rear window wash (blue-red)
6 - license plate light (white)
7 - (not listed)
8 - reverse/backup lights (black)
9 - radio dimmer (blue-white)
10 - parking lights right (brown-white)
11 - courtesy light (black)(blue-black)
12 -
13 - trunk/boot light (green), radio+acc (green)
14 - radio + batt (yellow-black)
15 - high level brake light (blue-yellow)
16 - radio rheostat (brown)
17 - rear fog right (violet-white)
18 -
19 - brake light left (yellow-green)
20 - brake light right (yellow)
21 -
22 -
23 - tank fuel pump (yellow-red)
24 -
7 - (not listed)
12 -
18 -
21 -
22 -
24 -
m2bandit
11-24-2014 05:51 AM
