1995 940 driveshaft different than the 1994 version
Why is the driveshaft for 1995 940 different than the 1994 version. I'm trying to locate a 1995 940 version of the part and no luck so far.
there's different shafts for different transmissions (AW71 vs manuals vs AW30-40, which I don't think were ever on US model 940's). and the 960s with IRS used different shafts.
absolutely be sure to mark both sides of the spline if you separate a shaft, they are balanced together, and must be reassembled in the same orientation. |
They should be the same.
