240 Firewall
I want to install a aftermarket siren with a switch going through the firewall. Does anyone know where I can locate a right location to insert a wire from the siren to the dash so i can hook up the switch?
RE: 240 Firewall
Look around at the rubber grommets.Some have a spot you can make a hole and insert the wire.
If not then just make a small hole in one of them and insert the wire. |
RE: 240 Firewall
Thanks!
