240 Front Rear Bushings not interchangeable?
Old Mar 7, 2011 | 03:52 AM
jigen3's Avatar
Default 240 Front Rear Bushings not interchangeable?
hi,
didn't get my other question answered yet (240 tie rod torque spec.) but had another question i couldn't find an answer to.
i noticed some sellers and manufacturers list the rear control arm bushing as specific (left or right) and others list them the same. the bentley service manual says they are not interchangeable. i have two bushings of apparently the same side and was going to install them on both sides, was wondering if anyone knew of the difference between the bushings if any? and what sort of consequences would happen if they were mixed up?
thx all
Old Mar 7, 2011 | 07:14 AM
swiftjustice44's Avatar
If you're speaking of the large bushings that mount on the rear of the trailing arm? They are the same from side to side.
37 ft.lbs-52 ft.lbs is the torque range on the tie rods...obviously not a critical measurement...just tighten the heck out of it.
Old Mar 7, 2011 | 12:03 PM
jigen3's Avatar
thanks for the torque info. was actually talking about the large bushings on the rear of the front control arm that have their own little holder.
Old Mar 7, 2011 | 02:18 PM
TIPSP's Avatar
Got Boost?
The poly reaplacements are the same for both sides of the front control arm bracket.
I dont see why the rubber ones would be any different.
91shelby
Jun 9, 2011 10:12 PM
Platinum52
Jul 17, 2009 07:33 PM
1956godzilla
Dec 10, 2008 12:59 AM
wojeepster
Aug 24, 2008 09:19 AM
jlentertain
Jul 30, 2008 06:40 PM
