240 No Main Key
240 No Main Key
Good day!
Yesterday I came to the realization that the only key I have for my 240 is the service key (can open the front doors and turn on the ignition, no truck access, no roof rack access). I can still open the trunk by unlocking the whole car, but if power locks ever fail on me with groceries in the trunk, I'm in for a nasty treat. I also can't remove the roof racks. What are my chances of getting a new main key? Do I have to call a dealership and get one shipped, or can a new one be cut by a local shop?
Thank you in advance
The valet key that won't open the trunk is fatter - the key won't physically fit into the trunk/glove box lock because it is too wide. A master key is the same cut - so you could get your valet key copied onto a master key blank to solve your problem. Or you can order a master key from a dealer using your VIN to get an exact cut, since copies are not perfect sometimes.
If your key fits into the trunk and glove box locks but won't turn - then someone has changed ignition and door locks, or vice versa.
Can't help you with the roof racks
volvodriver99
11-05-2020 02:04 AM
