tinkerbelle |
10-26-2015 12:17 PM |
740 distributor
Ok. I swapped cylinder heads in my 92 740 wagon. It's taken me 6 months because I had to learn as I went. I'm down to the 'easy stuff' I guess,just need a little info. All I have to do is put the distributor on,and the new wires,valve cover gasket, and valve cover. So, I'm just confused over how the distributor should be turned.It's cam-driven,attached to the back of the engine.Do I set the timing marks on the timing belt,etc,then put the distributor on? Which way should the rotor be pointing? By pointing, I mean does the bigger end point up, or the smaller?And since i have a different cylinder head ,does it matter how the camshaft sits in there? I've read that the rotor needs to point to #1 cylinder. How do you make that happen?:confused: You can tell I don't know much-it's a wonder i got this far !:D I wanna get this thing started before winter. Greatly appreciate generous and detailed info. BTW, my ignition is rex/regina,but my distributor is Bosch.(I know, but it's ok) thank you!!!!
