740 GLE Running Rough
could someone give me an opinion: volvo 740 2.3 16v engine code B234F 155bhp, the car came to head gasket change, before and after words it didn't run well and died, but when it runs it detonates(shoots) in the inlet manifold on quick accelerator pushing.
timing belt marks are good checked. throttle position sensor changed idle air control valve works checked spark plugs and wires ok distributor changed ignition control unit changed still doesn't run what could be the problem? |
Sounds as if timing is not correct. Re-check your timing and also the distributor installation.
fault code 3-1-2 is also displayed
Here is an article that may help a bit...
RWD - |
