swiftjustice44 |
09-13-2010 04:19 PM |
Well, either electrical or fuel. Probably safe to rule out low tire pressure. Are you sure the car has gasoline? Is it getting to the fuel rail? Do you have injector pulse? If it's an 89 or newer non turbo, it has LH2.4...could be a bad crank sensor located behind the engine, straight down below the distributor on the bell housing/block junction. Could be the fuel injection relay a/k/a the radio suppression relay mounted on the overflow bracket. Also, there is an ignition module located driver's side of engine bay behind the air filter box that can die. The fuel pump relay could also cause a no-start but that usually is intermittent long before they totally die. You really need to get some sort of repair manual and a digital multi-meter to do some fault tracing rather than replacing parts willy nilly.
