740 Regina Fuel Pump questions...
#21
OK, I'm reading this instructional essay: https://www.volvoclub.org.uk/faq/Fue...eplacement.htm
In the section where he discusses removing the quick connector, there's no indication of how far forward the sleeve should be expected to move in order to disengage from the tube. Then, he says to push the fitting (tube) forward as well, but it's difficult to understand how the tube itself could move toward the top of the sending unit if it is a snug and secure fit.
#22
#24
Update: Replaced the fuel pump, car starts up fine, but...idle is weird, so I pop the hood and what do I see? Gas literally pouring out from around the fuel pressure regulator. I pull, think "OK, replace the o-ring". So I replace the o ring. No joy. I call my Volvo mechanic to see if he has a fuel pressure regulator, but in the course of the conversation he sounds dubious that it is the FPR, like he'd never heard of one behaving in this way. But he did say you should be able to blow through it in either direction. So I attached a section of clean tubing to the return side, but can neither blow nor suck air through it. Has anybody here ever seen this kind of thing? I really don't believe the rail is cracked; I'm pretty sure the fuel I see leaking is blowing through the o-ring.
#28
Weird thing is you can find them from $15 to over $150.
Go figure.
#29
the FPR has 3 connecions. fuel goes in from the fuel injector rail, it goes out to the fuel return hose, and there's a vacuum connection used to modulate the fuel pressure according to the manifold vacuum.
so, by 'o-ring', I presume you mean the inlet connection between the FPR and the fuel rail ...
#30
#31
#33
That is as I thought; which apparently means this FPR has failed in a spectacularly dangerous way, spewing gas all over the engine block. I'm having a hard time understanding how my Volvo mechanic - who has been strictly a Volvo mechanic for several decades - seemed dubious about it, as if he had never seen this happen before.
#34
Well, draw your own conclusion and get a new mechanic if you have a choice. Better yet get knowledgeable about your Volvo and avoid shops as much as possible: you'll get a lot of satisfaction and save a ton of $; having an old Volvo is a good car to own and learn on--plenty of info and help on forums, internet, etc.
#35
As for learning to work on them myself, I've been a Volvo owner since 1982, and have been working on them since that time. I'm here now because I wanted to find tips/things to avoid regarding replacing the in-tank fuel pump, which I've now accomplished thanks in part to the info I picked up here. Thanks everybody. It was actually easier than I anticipated. I did have to go back and read the finer details about putting the face-plate back on. It really will not go with the seal mounted on it; the seal has to be put on the tank first and all matching faces lubed a bit (I used Vaseline) before sliding it in place.
Onward to brakes and A/C!
#36
Does anybody know if the fuel filter for this car is different than one for a Bosch system?
The listings on some websites indicate no; others suggest otherwise, using language like "Excl. Regina system"
I wasn't going to mess with it because it looked quite new. However, upon discovering rust in the fuel line I decided to pull it.
There was quite a bit of rust in the forward end of the filter. So I'm now pulling the fuel line and rail for TLC as well.
#37
#38
Disconnecting the lines from the fittings, I looked into the ends with a strong light and I see rust.
The fuel filter has been disconnected from the car. It is simple to look inside and see rust. Not rust on the surface, rust inside the filter.
Disconnecting the fuel pressure regulator from the rail, I see rust inside the rail using a strong light.
#39
#40
