'86 740 GLE won't start
Old Mar 5, 2007 | 09:48 PM
stevemark65's Avatar
Default '86 740 GLE won't start
I am looking for some advice - my '86 740 GLE (gas,non-turbo engine) quit on me while I was driving. I checked the fuel supply and there is no fuel pressure and the fuel pump isn't running. I took out the fuel pump relay and jumpered pins 3 and 87/2 and the fuel pump runs but the car still won't start. I tried a known good relay and the fuel pump doesn't run with the good relay. Any tips on further diagnostics? Is there a way of testing the ECU? BTW - where is the ECU located on this car?
Old Mar 5, 2007 | 09:52 PM
Default RE: '86 740 GLE won't start
The ecu is under the dash on the passenger side.
A power stage can do the same thing.
A speed sensor can do the same thing.
Old Mar 5, 2007 | 09:55 PM
ORIGINAL: tech
Thx - any tips on testing the power stage or speed sensor?
Old Mar 5, 2007 | 10:07 PM
Just to clarify - even with the good relay the fuel pump doesn't run at all when I turn the key on.
Old Mar 6, 2007 | 12:34 AM
Then I would check for power at the pump. It should atleast come on for about 30 seconds.
I don't have the spec's home maybe someone does that they can give you for the power stage.
The speed sensor you should be able to read on ohms and make sure they move up and down while cranking the car.
740GLEWagon88
Apr 17, 2011 10:08 AM
JayKShin
Jan 15, 2011 04:21 PM
Naikansan
Oct 18, 2010 05:09 PM
birdy67
Jul 8, 2010 01:13 AM
dalborn
Jul 21, 2005 09:52 PM
