-   Volvo 240, 740 & 940 (https://volvoforums.com/forum/volvo-240-740-940-12/)
-   -   87 244 fuses (https://volvoforums.com/forum/volvo-240-740-940-12/87-244-fuses-103883/)
tog244 Aug 9, 2020 09:43 AM
87 244 fuses
My 240 will pop fuse 8 as soon as the negative battery terminal is connected, time and time again. (I am using the correct fuse per the owners manual) There are a lot of things connected to fuse 8 and I was wondering if anyone else had this problem or had any suggestions on how to find the problem- my guess is its some relay or light but I don't know how to test for that.
hoonk Aug 9, 2020 10:04 AM
What is listed as being on that fuse?
tog244 Aug 9, 2020 10:52 AM
Interior light, glove box light, trunk light, engine compartment light, central locking, and the electric radio antenna
pierce Aug 9, 2020 04:46 PM
more likely, its a wiring insulation failure, shorting to the chassis. i'd check the wiring on the trunk hinge, thats a common failure place, or the central locking wiring at the drivers door
