'89 240 warm engine restart and stalling
Hello,
Car, 130k miles, runs strong and idles well, but started to have occasional trouble with starting only when engine is warm a few weeks ago-turns over, but won't fire. Today, stalled while driving and I was able to restart and drove home fine, but check engine light came on. Checked codes and got 2-3-2, 2-3-1, and 1-4-4. After reading forums about these codes, I'm not sure where to start. The temp gauge has sometimes fluctuated more than would seem normal, so I wonder if that could point to ECT? I'm not real bright, so looking for help. Thanks. |
My 92 240, had warm starting problem which was remedied by cleaning throttle body and changing gasket and air cleaner. Weeks later, the check engine came on with
2-3-2, changed o2 sensor and disconnected battery to clear code and turn off light. Car ran erratic until it adapted to o2 sensor, check engine light returned with a 1-1-3 code which is still under diagnosis. Books says to start with first code and following codes secondary. |
