-   Volvo 240, 740 & 940 (https://volvoforums.com/forum/volvo-240-740-940-12/)
-   -   92 940 sunroof seal replacement (https://volvoforums.com/forum/volvo-240-740-940-12/92-940-sunroof-seal-replacement-99517/)
Trisvvil 03-29-2019 02:06 PM
Hi, I'm new to these forums, I'm sorry if someone has already asked this question, but I didn't see an answer on here anywhere. My car has a metal sunroof, and the seal is in dire need of replacement. I am having a hard time finding a new one, so any help in locating one would be greatly appreciated.
pierce 03-29-2019 05:43 PM
the strip is Volvo part 3528809, but its NLA
https://www.volvopartswebstore.com/p...6/3528809.html
you'll need to find some sort of generic weather stripping thats the right thickness and trim to fit.
note that seal is mostly to keep wind and debris out, its not actually keeping water out, the water that leaks around the sunroof is collected in a tray that has drain hoses in the 4 corners, front two go down the A pillars, rear two go down the C pillars, all 4 end up under the car.
Trisvvil 04-01-2019 05:04 PM
Hey, thank you for the response. I appreciate it. Any suggestions on how to get the thing draining properly?
lev 04-01-2019 05:52 PM
You have to make sure the drain holes are unobstructed, two in the front corners, two in the back. I use a speedo cable to root the channels, the front ones are easy, the back are hard. I park facing front downhill if I have a leaker until fix it.
Trisvvil 04-01-2019 06:03 PM
Ok thanks I appreciate it
Baden 02-22-2021 09:48 AM
Go to:
Rock Auto dot com....we have found almost every part we need for our 92 960 volvo
lev 02-22-2021 10:13 AM
Rock Auto does not have that part, nor any other Volvo specific parts other than the usual generic maintenance stuff.
Baden 02-22-2021 02:10 PM
Actually they do. You just have to search thru the meriad of parts list. Like I said we have found 90 to 95% of our volvo parts there
lev 02-22-2021 05:16 PM
Actually if I can't find it, it is no use to me or anybody else, not sure what a "meriad of parts list" is or how one can get into it. Looking for that seal on Rock Auto shows nothing useful. If you have a special way to find it, please share!
Baden 02-22-2021 07:41 PM
Ok here it is:
Goto :rockauto.com
Click: volvo
Click: year-ours is a 92
Click: the style-ours is a 960
Then while in that window, go up to search bar and type in: sunroof seal
one will pop up..its 1.99 a foot...ours uses a 4 foot length
Hope that helps
lev 02-22-2021 10:24 PM
I tried it, for the '92 960, and no, no sunroof seal showed up... tried various other searches years and Volvo models, no dice. How recently did they have it?
act1292 02-23-2021 02:42 AM
Originally Posted by Baden (Post 495374)
Goto :rockauto.com
Click: volvo
Hope that helps
How about just posting a link?
Moetheshmoe 02-23-2021 02:23 PM
Here ya go
https://www.ipdusa.com/products/2249...1355688-140718
