240 power steering pump shaft noise
Old 03-24-2006, 04:48 PM
jae17's Avatar
Default 240 power steering pump shaft noise
My 1990 240DL (196,000) is making a "screeching?" noise which I traced to the power steering pump shaft. If I squirt a touch of WD on it, it goes away for about 30 minutes and then returns.
I'm assuming there's a shaft bearing that's worn out. Is this something that can be rebuilt, or do you just buy a new pump?
The steering function works fine.
Thanks for your input
Old 03-24-2006, 09:32 PM
Default RE: 240 power steering pump shaft noise
Are you sure it isn't the belt?
If it is the bearing in the pump get a new pump.
Old 03-24-2006, 10:08 PM
jae17's Avatar
Belts are new; time for a new pump.
Thanks for the help!
Jim
San Diego Ca
s60propshaft
01-15-2023 06:59 PM
MoneypitC70
2001-2013 model year XC70
10-26-2014 08:37 PM
al_ngl
11-23-2011 12:06 AM
Volvo-Profess
01-14-2011 05:55 PM
2002v70
10-17-2009 06:31 PM
Quick Reply: 240 power steering pump shaft noise
