940 won't start
940 sedan won't start. Turns over. Gets spark. Checked fuel relay and it clicks on start, no sound from fuel pumps. I'm thinking fuel pump, maybe rear. Any thoughts? If it is the tank pump, is it a bear to replace? Thanks.
I know on the 850 and 740 wagons you can get at the in tank fuel pump from the inside from over the tank by the back of the rear seat. They were both easy. A sedan is obviously different, but look in that area, maybe its similar.
Not to hard once you get the big cap off of the tank, if it's like the one that was on my 740 GLE.
Do you have to remove the tank to get the cap off? Or is it accessible from the trunk or rear seat? I inherited a Haynes manual but that is truly worthless.
