95 940 radio/stereo wire color codes
i just thought i'd post this, b/c it took me forever to finally find colors that matched the wiring in my car. so i hope this helps all the other do-it-yourselfers
i also have the factory installed amp located under the steering column wires into radio: LF + (Dash speaker) Brown/White LF - (Dash) Brown RF + (Dash) Grey/Red RF - (Dash) Grey Dimmer Yellow/White Rho + White Rho - Blue Battery + (constant power/ignition?) Pink/Brown colors could be Green/Red in some cars Ground Black Power Antenna Green/Grey(use this to go to your aftermarket pwr ant) maybe Orange in some cars and into the factory amp: Ground Black Battery + Pink/Black LF + (door) Blue/Yellow LF - (door) White RF + (door) Grey/White RF - (door) Grey LR + (rear door/deck) Yellow/Brown LR - (rear door/deck) Yellow/Grey RR + (rear door/deck) Green/Brown RR - (rear door/deck) Green helpful links: http://www.robdiesel.com/galleries/c...oval/index.htm (940 radio removal) http://www.installdr.com/InstallDocs...PDF/865001.pdf (for 7xx series but very similar and it tells you how to bypass amp, w/ pics) http://www.swedishbricks.net/700900F...0and%20Antenna (940 radio/ant related questions) --- and i have yet to ever find a harness that fits my radio and factory amp - repeated advice is to buckle down and do it the old fashioned way, which i'm now doing...i can post on the process if i succeed i hope all this helps |
