1990 Volvo 740 gl wagon fuel problems
Old 07-15-2018, 12:47 AM
Greenbutt's Avatar
Default 1990 Volvo 740 gl wagon fuel problems
Hey there so my fuel pump died the other week so I replaced that and the pump comes one and fuel is getting past the filter but not getting to the fuel rail. Replaced filter as well.
Old 07-15-2018, 02:08 AM
tony1963's Avatar
Messing with fuel is dangerous so I will give you fair warning before attempting to service the system. I prefer outside with fire safety equipment handy.
I suggest removing the filter and also the connection to the fuel rail. Check for flow by using low pressure air. You may have blockage in the line.
Also, you may not have cycled the key enough times to get fuel pressure all the way up the system.
Old 07-15-2018, 07:23 AM
jagtoes's Avatar
How do you know you are not getting fuel to the rail. How are you measuring it. Also how much fuel is in the gas tank. Is it greater then half a tank. Does the car start at all. Does the fuel pump run for a few seconds when you turn the ignition on. Are your spark plugs wet or dry. Need more info.
Old 07-15-2018, 12:31 PM
Greenbutt's Avatar
I pulled off the line to the fuel pressure regulator and the line is bone dry. I’m not very experienced with working on cars so I’m doing my best lol. I don’t have a fuel pressure tested so I put my thumb over the regulator had a buddy turn the key and try to start it and it cranks over but I couldn’t feel any pressure. How many times so I have to cycle the key? Never done anything fuel related before
Old 07-15-2018, 12:33 PM
Greenbutt's Avatar
How many tomes ones do I cycle the key. The car has now been sitting for a month because I haven’t figured it out and don’t have the funds to visit a shop.
Old 07-15-2018, 02:41 PM
jagtoes's Avatar
When you turn the key on without cranking the engine can you hear the fuel pump running for a few seconds. Did you check the fuel pump relay . if there is no fuel in the fuel rail then I would look at the relay. Pull it and check for burn marks on the bottom. Also check fuses.
Gardenhands
06-06-2012 08:56 PM
FASTER
11-13-2010 09:07 PM
colt1911
09-21-2010 06:24 PM
ian3
07-31-2009 11:59 PM
copycat923
01-27-2006 01:55 AM
Quick Reply: 1990 Volvo 740 gl wagon fuel problems
