Air Conditioning Not Working
Hello,
Need a little help here. My air conditioning doesn't work and wondering the step by step process in order to try and fix it. The compressor will kick on if the relay is bypassed Could this be a broken/cracked relay and or a burnt out fuse? Any information would be great. Thanks |
Originally Posted by tbuchan
(Post 462139)
Hello,
Agree with above.
The only way to get the compressor to turn on is to skip the relay all together.
So would the gauges need to be testing if the compressor isnt working? |
(Post 462196)
I am in total awe of the number of people who try to diagnose an AC system with a screw driver and a monkey wrench. You need a set of gauges and a basic understanding of both electric currents and refrigeration.
Without either, you are guessing and shooting what is known as the "parts cannon". Heaven forbid you spend a few bucks getting a proper diagnosis. I propose that we no longer give AC advice in this forum. |
Originally Posted by tony1963
(Post 462202)
Without either, you are guessing and shooting what is known as the "parts cannon". Heaven forbid you spend a few bucks getting a proper diagnosis. I propose that we no longer give AC advice in this forum. Done it a coulda times now. |
4 Attachment(s)
The simple fact is that the pre-1991 240s have a very limited AC system and will never keep up in a hot climate, anything over 85 degrees without a redesign. As a dealer selling Volvos for 20 years here in Birmingham AL, I can tell you that while I used to sell the dog out of those things, the AC was not up to par.
For all of the trouble trying to get an old 240 to cool down, you could buy a more modern Volvo that could refrigerate the State of Alabama. |
lol the ac in mine doesn't work ... but i have an alternative... 4 power windows that DO work;)
(Post 462230)
The thread that starts with "hey, my AC doesn't work, what do you think is wrong with it" gets old. Plus, trying to get cold air out of those old 240s is time not well spent, in my opinion.
While the old 240 has a following, the AC system on those pre-1991 models is not capable of keeping up with a hot climate, period. So, the best that I can recommend is a newer model that will run circles around that old 240. |
Originally Posted by jagtoes
(Post 462140)
I would suggest that you 1st get a set of AC gauges hooked up to the system and see what the reading are. Based on those results the next step can be determined. If low on freon then either a top off or a search for the leak. If system is up to proper charge then we need to look other places. Do the gauges 1st.
I am going to refer you to a licensed repair facility to perform any more diagnosis. While we are happy to help, I have concerns that you do not have the experience to properly hook up a set of gauges. The system can have up to 400 lbs on the high side and that's dangerous if you are not trained.
My suggestion is to seek professional help. |
Originally Posted by xactorocker
(Post 462326)
hey how do you you see how much freon your ac has in it
(Post 462334)
