Air Mass Meter Diagnostics Volvo 240dl 1988
Finally got the old carl running. With the air mass meter disconnected chugged to a used parts dealer. Tried one of his used air mass meters and low and behold the car ran with the AMF plugged in. Miracle of miracles. Just to put closure on this item, here are the resistance readings for the two meters. One good the other bad. The Bosch part number on this type of air mass meter is 0 280 212 007.
Bad Meter - 1 2 3 4 5 6 1 - 0 2.8 18k 19k 527 2 - - 2.9 18.7k 19.1k 527 3 - - - 18.5k 19k 530 4 - - - - 38k 19k 5 - - - - - 19k Good Meter - 1 2 3 4 5 6 1 - 0 3 25.4k 19k 527 2 - - 3 25.4k 19k 527 3 - - - 25.5k 19k 530 4 - - - - 44.6k 26k 5 - - - - - 1034 From the looks of this it would appear that there was a problem in the reading between the 5 and 6 terminals in the bad unit. The others seem to be relatively consistent. Hope this helps someone in the future. Keep smiling as always Jurij |
RE: Air Mass Meter Diagnostics Volvo 240dl 1988
Good News
