can anyone identify the source of this sound?
Sounds like the starter pinion gear is not releasing - the solenoid is supposed to pull it back when the starter is no longer energized. Could be the solenoid sticking or the gear not sliding on the shaft. If so a replacement starter is the easiest solution - and they are very reliable so a used part would be a reasonable choice (if it tests good)
Then I heard belts squeaking.
