Coolant Temp Sensor
Where the heck is this thing located. I’m sick to death of paying a mechanic to fix little things like this. Please help. |
It's under the third intake runner, screwed in the head with a plug on it naturally... It's hard to get to it with the intake manifold on but not impossible. Unplugging it the hardest, then usually with a long extension there is a straight shot onto it, forget the size, (19mm?)... Coolant loss is minor.
Do you think it’s possivle this could cause my cold start issues? With it loping for about 20 seconds. The engine runs fine otherwise. |
you test it by measuring the resistance when its hot, and when its cold. problems are as likely to be the connector or the wiring harness as the actual sensor.
Originally Posted by tylswil
(Post 469552)
Sweet thank you very much |
this guy changed out the CTS without removing the intake manifold. caution for language but like his style :cool:
Will this be in the same location as a 940? |
(Post 469585)
(Post 469585)
