Coolant Temp Sensor Voltage Readings?!
As you guys know, still having ECT issues.... okay, so this is the reading I was getting from the ECU pins with the ignition ON and the sensor plugged in... this cant be right? https://cimg7.ibsrv.net/gimg/volvofo...7f3798f7e.jpegPin 5 ( ground ) and pin 13. No voltage readings? I do get ~2.0ohms when I test for resistance, which I think is normal for 75 degrees F. |
There won't be any voltage reading if the connector is not connected to the ECU. To get a voltage reading, the connector has to be connected to the ECU and you need to back probe the connector - that means probe from the wire side.
According to the FAQ at brickboard, the resistance should be as follows:
Originally Posted by act1292
(Post 463916)
Thank you for the reply! I'm not very handy with electrical stuff, but I'm learning :). I didn't check the resistance when it was warm. I have 3 ECT's. 2 brand new ( ordered an extra because I thought it was faulty ) and the original one that came in the engine when I got the car. So, my problem is with the original sensor, the car starts up when cold, but does not start up when warm ( have to feather the throttle quite a lot ). So, I replaced it with a 12$ one from IPd. Well, with the new sensor the car doesn't start when cold... and it throws a CEL for Coolant Temp Sensor Missing or Faulty... I then tried my even NEWER sensor ( replacement for my new one, since I thought it was faulty ) and it does the same exact thing. So, I replaced it with the original sensor, and it starts up like normal, but of course it still has the hot start issue :( I talked to IPd yesterday, they are sending me a BOSCH ECT, so hopefully that will fix it.. But I can't see why the other 2 BRAND NEW sensors would be faulty? The resistance reading was normal. I haven't had a chance to try them when the engine is warm because it kills my battery trying to turn it over long enough to get it started. I may go home today and boil them and see what the readings are. Either way, it should still start the car when cold given that the room temperature readings from all 3 of the sensors are within normal range... Any ideas? |
2 K Ohms (aka 2000 ohms) would be in normal range, 2.0 ohms would most assuredly not be.
Originally Posted by pierce
(Post 463929)
