act1292 |
12-01-2011 07:10 AM |
The driveshaft is in two pieces. As Lev said, disconnect at the differential - 4 bolts. After that, the rear portion of the drive shaft should slide out by pulling it towards the rear of the car. You can then stow the rear portion in the trunk. The front portion can stay.
Before you disassemble, make alignment marks on the front & rear shaft pieces so that you put it back exactly the same way. If you don't align them properly when re-assembling you will end up with drive train vibrations. I would also make alignment marks where it bolts to the differential as well.
