-   Volvo 240, 740 & 940 (https://volvoforums.com/forum/volvo-240-740-940-12/)
-   -   Electrical Help, Regulator? Fuses? (https://volvoforums.com/forum/volvo-240-740-940-12/electrical-help-regulator-fuses-5845/)
BravePotato7 May 18, 2006 12:34 AM
Okay, so as I said in my new member intro(not that anyone actually reads those), my younger brother recently had an '86 240DL bought for him(for $150, blue on blue), but it doesn't run. Its in otherwise good condition. Its been sitting less than a year, the battery leads have some corrotion and its obviously dead. I'm going to replace it and see what happens.
But the lady that it was purchased from said it was looked at and they said the regulator was bad. I'm assuming thats the electrical regulator. So, where is it and how do I replace it? Any of you guys or gals got one laying around you want to sell me? (did a search with nothing of help)
Further more, do these things have fuses? Where the hell are they? I'm driving an 86 Mazda RX-7 and those are supposed to be ALOT more complicated. But damnit I couldn't find them. Lol.
Is there a site I can find information on different Volvo models? DL doesn't mean diesel does it?
Thanks all for the pointers.
tech May 18, 2006 12:42 AM
RE: Electrical Help, Regulator? Fuses?
DL was a model of the car Mostly consisting of trim packages and wheels.
The regulator could be either the Voltage regulator/Brush pack in the back of the Alt.
But it could also be a Fuel pressure regulator. Which is mechanical and is located on the end of the Fuel Rail it has a vaccum line going to it.
Does the car run at all?
Or did she say it was dead from a power issue?
Try jumping it and see if it runs but runs crappy.
BravePotato7 May 18, 2006 12:55 AM
Hey thanks! Much needed info. I'm not sure which regulator she said it was. I have yet to talk to her directly. I'll ask though. No I didn't try jumping it yet though. I plan on trying, or just buying a new cheapo battery on Friday sense as of now I have the day off. I want to get this at least running by the 30th of this month for my bro's birthday. Haha he really wanted a Vovlo. I snapped a few pics w/ my phone. I tried the key but it was completely dead and its still at their house cause the tires are chewed.
So IF it is indeed one of the regulators, I'll either have to replace the alternator or the one at the end of the fuel line right? Pluse probably the battery. It looked like a new Interstate but it might be bowing on the side. Couldnt tell if it was my imagination.
BravePotato7 May 18, 2006 12:56 AM
Oh, and as far as fuses? Where the hell are they?
tech May 18, 2006 01:27 AM
The fuse box is located in the A-pillar when you open the door. Just by the bottom of the dash by the door.
You will see a cover with a turn clip at the bottom of the panel turn and lift.
TIP:Note and remove all fuse and clean or replace.Also clean fuse box. They are known to corrode.
If the regulator in the Alt is bad you can just replace the Brushpack/Regulator.
http://www.fcpgroton.com/volvo240eng_electrical.htm
Look at the voltage regulators.
http://www.fcpgroton.com/volvo240fuelpump.htm
Look for fuel presure regulator.
BravePotato7 May 18, 2006 08:25 PM
Wow dude, thank you so much for the great help. I'm going to try and charge it probably today. I'm sure I'll have more questions.
tech May 18, 2006 09:34 PM
No problem I am here just about every day.
Mostly at night.
BravePotato7 May 18, 2006 11:17 PM
What do you think'll happen if after I replace the battery and probably fuses, it is the voltage regulator? Or if thats okay what'll happen if the fuel regulator's bad?
tech May 18, 2006 11:21 PM
If the regulator is bad the battery light should either be one bright or be on Very dim.
If the fuel regulator is bad it might run like crap.
BravePotato7 May 18, 2006 11:25 PM
Sweet, but either way sounds drivable, at least from the sellers hours to mine. Correct? If the volt. reg.'s bad, will it drain the battery?
BravePotato7 May 19, 2006 12:49 AM
Dumb question, but DL's the upper trim package not diesel right?
tech May 19, 2006 01:14 AM
Not sure exactly which package it is but I know it is not Diesel.
It should be drivable. But for how long not sure if it is the Voltage regulator.(Hopefully you don't live to far away)
Also forgot to tell you try pulling the Vaccum line off the fuel pressure regulator and see if there is gas indside it. If there is then it is bad.
If the Voltage regulator is bad leave everything off and drive it in the Daylight. You should get a little bit out of it.
BravePotato7 May 19, 2006 05:34 AM
Awesome thanks, that'll help alot. I'm going out to see it tomarrow. Its not really very far at all, the other side of town(about 15 miles) and I really only need to drive it once till I figure it all out.
BravePotato7 May 29, 2006 09:22 PM
Okay so I got it started by just changing the battery and fuses. Then drove it to wash it, then on the way home it just died in the middle of the road. Pushed it, then had it towed. Getting it back tomarrow(my bro's bday; cutting it damn close). So far they've said it was a timing issue. Teeth missing, something something. I'll have more info tomarrow. The gauge cluster still needs to be replaced though.
tech May 29, 2006 09:30 PM
The timing belt Teeth Came off due to old belt.
If you only could have gotten it home. I could have helped you figure it out and replaced it.
What was wrong with the Speedo cluster again?(Just to refresh my Memory) (Senior moment) LOL
BravePotato7 May 30, 2006 01:28 AM
Lol haha. Senior moment. Umm.. the problem is it doesn't work. None of the instraments looked like they were working(speedo, temp, gas, etc.)
tech May 30, 2006 10:53 PM
Any Lights work at all?
BravePotato7 Jun 1, 2006 08:25 AM
Yeah I think all the lights work. Damn mechanics say the timing didn't do it. Talking about putting in a replacement engine.
tech Jun 1, 2006 08:37 PM
What exactly happened?
What are they telling you?
BravePotato7 Jun 10, 2006 12:58 AM
Ok finally got it back! Lets see they replaced the timing(belt?, some teeth were missing), the seals behind that, a head gasket and ... I think that was most of it. Some $600. Oh well, that still puts it under $1k for the car and repairs. :)
