Engine swap for a '82 244
Hi all,
I was just wondering if anyone knows if the driveline out of a '90 model 740 would go into a '82 model 244 without to many issues. Cheers SVNWGN |
RE: Engine swap for a '82 244
It should fit. You will have to use the 740 engine mount brackets. You will also have to use the 740 computer and wiring harness.
Not sure but you might have to swap the fuel pumps as well. If you have CI injection the fuel pressure is higher. |
