Exhaust Fix 89 240DL
Hello All,
I have a 89 240 and the exhaust pipe below the manifold where the two pipes turns into one gave way. The weld broke and I was driving for a week with a busted weld. It sounded like a Cessna airplane. I found a pipe for it at Advance Auto for $115.00 and it fit like a glove, only problem was it had a hole for the 02 sensor and the catalytic converter already had one. That was no big fix. After driving that day my check engine light came on, I think it could be the 02 sensor not getting exhaust. My question is where do I reset/clear the computer. i see the place where you test it but don't see the reset. thanks:) |
Originally Posted by palerider
(Post 234304)
Hello All,
Originally Posted by volvoguy2323
(Post 234321)
Driver side fire wall little black box. remove cover and take prong out and insert into hole #2. Hold button down for 2 seconds and release. You will see a seriers of flashes example..1 1 1 which means system is good. O2 sensor code is 2 3 2. Make sure you repeat until all codes have trepeated themselves or it will not let you clear. for example if you get code 2 3 2 and then you hold button down again and release and you get same code 2 3 2 then you can reset..to reset hold button down for 10 seconds and then release.. red light will come on. hold button again for 8 seconds and release...computer should be cleared. also put prong in hole # 6 and repeat process. Obviously you will have the key on the on position or car running..hope this helps and good luck!!
Thanks for your help, it was the 02 sensor. I cleared it out. Thanks to ya again. |
TThanks it worked
No problem that's why I'm here :)
