Fan Belt and Alternator
Hello,
I have a 93' 940 turbo and i was wondering how hard is it to change the fan and alternator belts myself. I would be doing this and anything close to this for the first time, I am a college student and I am trying to save as much money as possible. Any help will be greatly appreicated. Also which belt goes on first if its a easy job? Thanks in advance, Jay D. |
RE: Fan Belt and Alternator
It is pretty easy.
One 13mm nut for each comp. Then a 10mm screw to adjust belt tension. Loosen the Comp. you want to remove the belts from. Then remove the belts one at a time putting them in an order to install the new belts in reverse order. |
Thank you very much........... I think I will try to do it myself instead of paying someone to do it.
Jay D. |
One more thing just so that I correct in my statements, which belts go around the alternator I know has to be the alternator belt and the other is what?
Some just go around the alt. and crank.
Some go around the Alt.,water pump and crank. |
