headlights
We replaced those foggy 'tv panel' headlights on our 240 with the Depo brand ones that are exact copy of the stockers, from ebay. the Depo lights use a different plastic that doesn't yellow in the sun the ay polycarbonate does, so they last a lot longer.
putting HID (Xenon si the same thing) in a halogen headlight reflector will make some major glare as the HID light source isn't the same shape as the stock halogen filament.... LEDs have much the same problem.
the ONLY way I'd consider retrofitting HID would be to use projector headlights, such as are used on late model BMWs, and make some sort of custom front end frame/mask to hold them. lotta work, and would look pretty funky unless you're really good with custom fabrication.
Swer
01-09-2015 09:50 AM
