Instrument Cluster Lights
Old Oct 23, 2007 | 02:51 PM
funnyguy44444's Avatar
Default Instrument Cluster Lights
The instrument cluster lights on my '82 244 stopped working a couple night ago. I took out the cluster to try to see what is going on with them. The bulbs aren't burnt. I can't figure out why they won't turn on. Aren't they somehow hooked into the lights for the clock and the lights on the center pannel? I'm guessing they are becuase those stopped working as well. What would be causing them all to not turn on?
Old Oct 23, 2007 | 04:22 PM
billofdurham's Avatar
Default RE: Instrument Cluster Lights
Have you accidentally turned the panel lights rheostat down?
Old Oct 23, 2007 | 09:56 PM
Nope it is all the way up. I think it migth be the problem though. The lights aren't getting enough voltage (about .3 volts) and I don't know what else would be causing it to not get voltage.
Old Nov 15, 2007 | 06:52 AM
rgraves1's Avatar
Did you fix the problem? I am having the same problem
Old Nov 15, 2007 | 09:40 AM
jks2's Avatar
Have you checked to see if the fuse is OK?
Old Nov 15, 2007 | 10:33 AM
iamnickcarter's Avatar
My rheostat stopped working shortly after I bought my car, I had to run a new switch but ended up with a much cooler looking on/off **** instead of messing around with dimming.
Old Nov 15, 2007 | 05:19 PM
Thats what I ended up doin too. just running a hot wire off the battery with a fuse straight to the lights. works fine now.
SB245
Jun 6, 2023 01:50 AM
volvo5volvo
May 29, 2012 05:46 AM
jpravi8tor
Sep 13, 2009 01:37 PM
elmo_allen
Jun 20, 2009 10:35 AM
siuc_gator
Nov 3, 2008 04:28 PM
