My 90 240 DL instrument Pannel went out.
My instrument cluster went out about 2-3 days ago. All the gauges do not work except for the clock. But the light **** on the left works for turning on my car lights and so does my radio. So I replaced all the fuses that I thought might be bad and that deal with the instrument cluster and with what fuses I had on me. It still will not work, what can I do to fix it, what might be the problem? Also are all the fuses that I have in the correct spot?
Red fuse: 16A
Blue fuse: 25A
White fuse: 8A
the fuse panel cover should have a list of the fuses for your car, and what size goes where. I don't remember the 240 having that many red ones, I think there were more whites, but I could be wrong, its been years since my 240 went off to college with my girl and eventually got scrapped for getting too moldy inside due to water leaks
ok, looking in the wiring diagrams for a 1990, I see.....
1 - 8A - cigar lighter, tailgate wiper, power mirros, radio, antenna
2 - 16A - windshield wiper, horn, headlamp wiper
3 - 25A - heater fan
4 - 8A - in-tank pump, Oxy sensor (lambda) preheater
5 - 16A - turn signals, reverse lights
6 - 16A - ? not used in LH2.4 ?
7 - 8A - brake lights
8 - 8A - clock, courtesy lighting, trunk light, central locking, , radio always-on power
9 - 8A - hazard lights
10 - 16A - power windows
11 - 16A - overdrive, heated rear window
12 - 8A - seat belt reminder, power window relay, air conditioning
13 - 16A - heated seats
14 - 8A - rear fog lamp, switch(?)
15 - 8A - left parking/tail lights, license plate light
16 - 8A - right parking/tail lights, instrument lighting, indicator lamp.
fuses 1-2-3 are powered when the key is in I or II (accessory or run)
fuses 6-7-8-9-10 are always powered
fuses 11-12-13 are powered in II (run) only.
others are parts of various circults
This is how they are now.
And now my check engine light is on..
I believe I had put in the wrong fuses for my fuse box because when I went to orilleys to get a couple more of the white fuses and I had already replaced most of them with the lower fuse and my car shut off while I was leaving. And wouldnt start unless I put the red ones back in.
How to read the engine codes on 1990-1993 Volvo 240
As for the over heating, its either the water pump (common) or the temperature gauge compensator board is giving false readings. Does the gauge immediately shoot up when you star the car?
So here is a video of the codes that are reading off my car..
Can someone read these for me? So here is a video of the codes that are reading off my car..https://share.icloud.com/photos/0PPZ...JF4IR2zgw#Home
That bit just confuses me, since the water pump and fan are mechanically driven, I dunno what the issue is.
And here is a video of my temperature gauge slowly going up.. https://share.icloud.com/photos/0bAN...4rypvFCsQ#Home
Here is a video of my temperature gauge going up as I drive.
