Is my '92 940's o2 sensor bad?
Howdy everybody.
The Check Engine light came on this week in my '92 940. The car has 160k miles. I checked the code and it is 2-1-2,Oxygen sensor signal missing or faulty Oxygen sensor. I checked the readings on the O2 sensor with the engine at operating temperature and they varied between 0.026 and 1.261 volts. Is my O2 sensor bad? The engine runs fine, except at idle. Theidle isn't as smooth as it was before the Check Engine light came on. Thanks. |
RE: Is my '92 940's o2 sensor bad?
Did you clear the code?
ORIGINAL: tech Did you clear the code? |
Do you have an exhaust leak or a vaccum leak?
The sweep is good on the sensor. Maybe intake manifold gasket bad. |
ORIGINAL: tech Do you have an exhaust leak or a vaccum leak? The sweep is good on the sensor. Maybe intake manifold gasket bad. |
They are kind of known to warp. You might need to double gasket the joint.
RE: Is my '92 940'
ORIGINAL: tech They are kind of known to warp. You might need to double gasket the joint. |
RE: Is my '
That leak should be before the O2 so yes it will throw the code. But still check for an intake leak as well.
RE: Is my '
ORIGINAL: tech That leak should be before the O2 so yes it will throw the code. But still check for an intake leak as well. So far, the leak seems to be fixed. (fingers crossed) I cleared the code. It hasn't come back. Thanks. |
