my 940 needs alittle help
This past week I bought a 93 940gl
It'll be my daily driver to and from work It's got 120k and I'm enjoying it Just wondering is these are known problems 1 while driving around the temp gauge is bouncing what could cause that? 2 sunroof doesn't work what is the most common cause of failure The other problems ill figure out they are minor Also is there any known performance suspension for my car, I like my cars to handle around turns Thanks for any info |
For the sun roof, check the fuse. If it is good, the most common failure is the sun roof switch on the dash. Bouncing temp needle could be as simple as a loose connection or as much as a bad circuit board in the cluster.
