My 940t sucks and i need some help.
Before i bought my car, i accidentally posted it as a 760, because i wasnt sure of the numbers. Anyways, i have a 940 turbo, auto, and it seems to run slow.
http://s277.photobucket.com/albums/k...sdigmiatas/car garbage/?action=view&current=SNC11861.flv There is an Acceleration vid right there. https://volvoforums.com/m_125479/mpa.../tm.htm#125958 Theres a link to the thread i made in the wrong place. I have tried un plugging the plug infront of the cat, checked as best as i could for boost leaks. The car has new plugs and wires and dist cap and fuel filter and stuff on it. Even though i know the plugs are champion and junk. Also, after you run it for more than 10 minutes, it wont fire back up. It will crank and crank and crank, but it wont fire. Like there is no spark. But if you shoot some ether into the intake it fires right back up and runs the same.. slow way it did. It doesnt die or anything. Im lost. The engine codes check out fine it just goes 1-1-1 and thats it. Well if you have any ideas, i would appreciate it. I dont have the money to go buy all new sensors, so any help would be appreciated. Thanks! |
RE: My 940t sucks and i need some help.
Go to www.stepbystepvolvo.com for free 740 no-start guide. Has some info for the 940.
