Volvo 940s missing
Volvo 940s missing
Hi my 1992 volvo 940s estate is missing,it started to miss about 6 weeks ago then after i parked it up and drove it the next day had no problems until yesterday where it was missing bad after driving along.Also i had my windscreen washer jets cleaned yesterday and the tube put back on the windscreen washer pump.Also my speedometer is flicking up to 50-60mph when only going 2o mph or so then it seems to settle down after a while going back to normal speed.Plugs and leads the cause? Or another cause loose connection somewhere or a sensor maybe?
Any help appreciated got my mot in a week
cheers sean
cheers sean
An engine misfire calls for an evaluation, starting with what used to be called a "tune up"... Plugs, wires, rotor, dist. cap, etc. There may be other causes, however: vacuum leaks, fuel issues, bad head gasket, etc, but the ignition system tune up is a good place to start.
The speedometer issue is most likely due to bad capacitors in the speedo itself and there is no easy cure--need a new speedo or replace the capacitors which is a fiddly procedure in the best of cases. For some reason '92s are particularly afflicted with bad speedos.
