piston rings/ gear oil
That doesn't necessarily mean you need to replace the rings in that cylinder. You didn't notice the motor was missing prior to pulling that plug wire? It could be a handful of things not causing it to fire on that cylinder. You need to perform a compression or leakdown test. What was the condition of the plug when you pulled it?
The piston rings on a Volvo aren't any more difficult to replace than those on any other car. You know the procedure, do a compression test to find the cylinder with the bad compression (if the one you suspect is only like 10 PSI off the rest then bad compression is not your problem) and definitely do a leak down test to find out if the leak is or is not between the piston and the wall of the cylinder before you take anything apart, unless this is a particularly high mileage engine it is more likely the valves leaking. Also when dealing with anything mechanical, remember it is most likely that the culprit is that which you messed with most recently, in this case the head gasket.
The transmission fluid goes in the same way it does on almost all manuals, there are two plugs you can unscrew on the side. I'll say this being as the others have suggested that you may be inexperienced, let the transmission cool down first. If it's an M45/46 I think it takes ATF. Recycle your old fluid.
pj91gsx
09-07-2008 12:39 PM
thoroughbred
01-15-2008 10:19 AM
