power antenna
I think the root of my radio not working is just that my power antenna doesn't go up although the radio seems to turn on. Maybe this is a common issue but maybe not.
In looking for replacements I found 2 from Partsgeek: one around 75 and one around 200 and one on eBay for about 50. I want to save as much money as I can, the 200 looks like a direct replacement, the 75 I am unsure about, and the 50 looks like a general antenna and would probably need to be wired in. Basically do the 50 or 75 look like they would be worth it or should I bite the bullet and get the 200 one. https://www.partsgeek.com/catalog/19...=power_antenna https://www.ebay.com/itm/Replacement...a4a91ab02aaadf |
Originally Posted by tog244
(Post 489551)
https://www.fcpeuro.com/products/vol...UaAtplEALw_wcB Or you could find a generic manual aftermarket antenna that bolts onto the fender and pushes all the way down for car washes - I used to sell them for $14.95 - And looks like you still can find them for that! https://www.bestbuy.com/site/metra-u...&ref=212&loc=1 |
How do I know if I only need to replace the mast? Also, could you briefly explain how the antenna extends so I can understand it better?
(Post 489567)
If you have a mast you can pull it up manually to see if that's your radio problem - Or FM will work on strong stations without an antenna - |
