Random stalling, gas smell, but idles fine. 1989 245 lh2.4
Hey all, posting this from mobile so please forgive my formatting here. I am having a serious issue with my 240 wagon (which is also my only vehicle, adding to the stress).
Yesterday I drove 80 miles to a friends house, which is a normal trip for this wagon. On my way back my car stalled about .25 miles from his house. The rest of the drive was filled with stalls and near stalls. This is an automatic by the way.
So, here’s what happens. The engine will be running fine, then suddenly the rpm just goes all over (doesn’t shoot up, it’s an up and down in a decreasing way). Sometimes the tach drops to 0, then pokes back up to 800, then back down until recovery or death. The car makes the cartoon “my car is breaking down” noise, has a gas smell/maybe burning smell. It always starts right back up again but the issue will return at intermittent intervals.
I swapped out the fuel pump relay and the replacement seemed to help, so for diagnostic reasons I put the old one back. I have a switch and wires set up to jumper the pumps and bypass the relay. When it tries to die I hit the switch (no luck). I put in the new relay and same issue.
I also tried cleaning the connections on the ignition amplifier, but I’m not sure if the loose connection I found (pin coming out of the rear of the connector) was something pre-existing or if I did that. I would drive the car but there just isn’t a good place to break down around here, so it’s terrifying. Idling in the driveway it’ll sit happily for a long time with no issues until I shut it off.
Hopefully this makes sense. I’ve owned this car for 5 years and have overcome everything it’s thrown so far, but have never been able to make it stop smelling like gas. Everyone says it runs beautifully but rich.
Also it will not run without a MAF. It might for a few seconds but it usually stalls. People always suggest to unplug it and try but I’ve never been able to.
Here’s a list of everything done in the last 2 years that might be related:
Wires, cap, rotor, plugs
intake manifold gasket
fuel injectors
engine temp sensor
crank position sensor
exhaust manifold and flange gasket
02 sensor
timing belt plus front seals (May last year)
fuel pressure regulator
both fuel pumps
fuel filter
in tank pump sender (new)
fuel injectors
engine temp sensor
02 sensor
both fuel pumps
fuel filter
some 89 LH2.4's have a suspect ECU with a pink label, these have a Bosch part number ending in -561 ...
See this table: https://www.volvoclub.org.uk/faq/Eng...ReferenceChart
If the problem is with the ECU I wouldn't expect to smell gas when the engine cuts out since the failure of the pink label ECUs is in the circuit that drives the fuel pump. Failure of the circuit would mean the pump won't run and therefore no gas. Also you mention that you have a switch in place to bypass the relay when it fails and that didn't help. This kind of rules out a fuel supply issue. If you do spring for a replacement ECU, make sure it is an LH 2.4. They would all be post '89 years.
1989+ 240's and non-turbo 940's use exactly the same engine and transmissions. ECU and ICU are interchangable assuming they are the same EGR or non-EGR. Many of the newer ECU's don't use the cold start injector, they just increase the spraying on the main injectors, but you can leave your cold start injector in place, it won't do any harm
Bricklover (08-11-2020)
jdarlin1
11-07-2008 11:50 AM
