-   Volvo 240, 740 & 940 (https://volvoforums.com/forum/volvo-240-740-940-12/)
-   -   scanner/ultragauge compatibility (https://volvoforums.com/forum/volvo-240-740-940-12/scanner-ultragauge-compatibility-52891/)
brickrunner Apr 23, 2011 08:26 PM
I would like to know if a 1994 Volvo 940 is compatible with an OBDII scanner. The reason that I ask is because I want to use an ultragauge. UltraGauge Automotive Information Center and OBDII Scan Tool.
MasterBlaster Apr 24, 2011 03:37 PM
If you still have the "mumbley-peg" diagnostic connector attached to the left strut tower brace, then no, you don't have OBDII.
brickrunner Apr 24, 2011 03:57 PM
Thanks, I'll check and see if I have it or not.
lev Apr 24, 2011 05:10 PM
No 940 has OBD2. As the car's run ended in 1995 in the US market, that system was never implemented; it was mandated with 1996 models...
brickrunner Apr 24, 2011 09:33 PM
No, I don't have OBDII. I guess I'm out of luck with the Ultragauge. :(
