Simple Clutch Question .....
1983 240 Wagon 4 speed with OD
I have to push the clutch pedal very, veryhard to the floor if I want to change gears. Is there an easy adjustment somewhere so I don't need to push the clutch pedal fully to the floor? Thanks. |
RE: Simple Clutch Question .....
yea you need to adjust the slave cylinder probably. I'm not sure how to do it on this car because mine is an auto so i haven't worked on on the manual transmissions. It is pretty easy in other cars though ususlly just locate it and loosen a couple bolts, make an adjustment and retighten them.
The adjustment is where the cable attaches to the transmission.
