Starter Inhibitor Switch
So, yet another thing has broken on my volvo 240. My car won't start. Initially I thought it was the neutral safety switch, but I looked in the Bentley manual and there's a starter inhibitor switch. So, I assume its at fault. I looked up the part on both FCPEuro and iPd and its no where to be found. If its possible, is there a way to bypass the inhibitor switch if its a hard to come by part?
FYI: its not the starter, basically it's like the car thinks it isn't in park, and I just had a new starter put in.
Thanks!
Evan
Thanks!
Evan
Alright! So I tore into the inhibitor switch (good god was it a b**ch to get into, I broke it in the process) it was indeed the problem. I kinda have it Jerry rigged to where I can get my car started. Also, I now realize the neutral safety and starter inhibitor are the same thing. So yay! It's a fairly cheap part and I can replace it. And my car still *somewhat* is drivable!
ouch. Do you know how to curb your tires? This is a skill I learned in San Francisco, where its legally mandatory (park on a hill without properly curbing your tire, you get a ticket).
the safety neutral switch....ok...I thought it was something I had not seen before...the "inhibitor" word freaked me out...
I was in Laguna Beach, CA and had to park on a very steep hill facing towards the top of the hill and turned the steering wheel full right....back of tire touching the curb...correct right?
Wouldn't that be a full left? If facing uphill.. and back of tire was touching curb? lol. And Pierce, it's our driveway. Its on a gentle slope, and my car will slowly roll down it.
well, if you were on the left side of a 1 way street facing uphill, then you would turn to the right
my rule parking in SF was the car should not roll with the brake off in neutral (or with the clutch in, at the time I had a stick shift), THEN you set the parking brake and put it in gear.
extra scary, there's some hills in SF so steep your tires can hop the curb.
you'll have to follow those wires to see where the plug is. the diagrams for the older models were remarkably vague as to connector locations... my guess is, somewhere between the carpet and the console hump.
